Now At Costco.....
Discussion in 'Shelby Cobra' started by DJR, Jul 29, 2012.
  1. DJR
    DJR Well-Known Member
    Ontario,Canada
    You just never know what Costco is going to offer up next!:D
    The Ultimate Hot Rodder's Garage Package from Costco.com is a dream come true for any Hot Rodder. You get the Motofloor® Garage Tiles for your garage to give it that professional look, and a two ton breakdown engine crane with jack stands and a jack, but you get la pies de resistance... a Kirkham Motorsports 427 KMS/SC component vehicle to park in your professional garage.
    Costco.com brings you the all handcrafted aluminum Kirkham Motorsports 427 KMS/SC component vehicle. Kirkham roadsters begin life in a former Polish MiG fighter factory where craftsmen have generations of experience fabricating high performance aircraft. Kirkham has taken the same craftsmanship and technology to build the finest roadster on the planet. All you need to do is add an engine and transmission (not included) and your chariot of fire will come to life. Buckle up, put it in first, and hang on for the ride of a lifetime--forget about keeping up with the Jones'...PASS THEM!
    The 427 KMS/SC is our version of one of the most iconic sports cars of all time. From the curvaceous good looks of its exquisitely crafted aluminum body, to the incredible road holding capability of its race proven suspension this car screams beauty and performance. While other manufacturers use mix and match components to build a replica, our cars are built from the ground up with parts engineered as a package to do one thing...perform. Whether its choosing the best shock absorber and spring package, redesigning the hand brake lever in billet aluminum, or choosing quality electrical components every part of a Kirkham Motorsports roadster is designed to perform to the highest standards.
    More Details
    Interior
    Our seats are each built by hand and covered in leather, not vinyl. We use a true tuck and roll technique to make the pleats in our seats. While this sounds like a small detail, true tuck and roll is much more labor intensive than other methods but results in a more durable, better looking finished product. The wooden steering wheel is 15 inches in diameter. Gauges used are produced exclusively for Kirkham Motorsports. Maintaining the classic good looks of original style gauges, including the reverse rotation speedometer, they are 100% electronic and far more accurate and reliable than the original mechanical counterparts. The dash is also trimmed in leather.
    Body Finish
    The body is aluminum polished to a mirror like finish with 'brushed' main stripes. Many are concerned with care of this finish but in reality it is not any more difficult than caring for a high quality paint job. Use a quality car duster to remove dust and if you get a scratch or nick, you can easily use aluminum polish on a soft cloth to get rid of the blemishes. Most customers use plain water to rinse the car off from time to time or window cleaner for tougher grime.
    Engine Compartment
    The engine compartment is set up to accept an original or reproduction Ford 427 FE engine. All of the electrical wires, fuel lines, gauge sending units and water hoses are provided and ready to be connected to the fire breathing engine of your choice. The car is set up to use either the Tremec TKO 600 5 speed transmission or a Ford Top Loader transmission.
    What is needed to complete the car
    Kirkham Motorsports sells component vehicles. In basic terms this means that we sell the car without a drive train. A drive train includes the engine and transmission assemblies. Parts needed to complete your car include the complete engine (engine with carburetor or fuel injection, air cleaner, ignition, water pump, alternator etc...) and the transmission assembly (transmission, flywheel, clutch, bell housing, pressure plate, etc...). These parts are readily available from several sources and Kirkham Motorsports can provide a list of recommended parts and vendors. Registration is the responsibility of the buyer. Component vehicle registration laws vary from state to state. Please check your local laws for more information.
    Standard 427 KMS/SC Includes:
    Aluminum Body:
    aluminum body mounted and riveted to the subframe
    hood, trunk, doors & latches
    aluminum interior panels
    hood scoop
    fiberglass foot boxes
    windshield
    roll bar
    jack hooks
    Cockpit:
    rear view mirror
    Moto-Lita 15" wood laminate steering wheel
    gauges
    leather seats
    lap belts
    carpet
    shifter handle, knob, boot & trim ring
    Electrical:
    head & tail lights, front turn lights, license light
    wiper system
    wiring harness
    relays, horns, switches, & fuse box
    battery tray & cables
    Mechanicals;
    aluminum radiator w/ mounting hardware and fan
    steering system
    brake & park brake systems
    hydraulic clutch master cylinder & lines (ready for customer supplied throw out bearing assembly)
    throttle linkage, complete (fits customer supplied FE or Windsor motor w/ carburetor)
    fuel tank
    Suspension:
    original style, tubular suspension
    billet aluminum knockoff wing nuts
    Wilwood 4 wheel disc brakes
    coil-over shocks
    15" Trigo wheels with 245 & 275/60-15 tires
    Dimensions:
    Wheelbase: 90"
    Height: 47"
    Width: 68.75"
    Length: 153"
    Weight: Depends on engine and transmission choice.
    Options also included with this car:
    full body polish
    brushed main stripes
    aluminum hood scoop
    powdercoated steel frame
    polished stainless roll bar
    billet jack hooks
    brake scoops
    stainless heat shields
    ferrules
    billet tank straps
    42 gallon tank
    wheel well foam installed
    carpet installed
    sun visors
    wind wings
    billet pedal assembly
    powder coated rear bulkhead
    15 inch wood steering wheel
    leather covered dash
    6 point seat belt (drivers)
    halon fire system
    fresh air drivers side
    fresh air passenger side
    sealed battery
    battery cut off switch
    radiator tube set
    billet coolant tank
    complete oil cooler assembly
    engine mounts
    billet distributer hold down
    billet alternator bracket
    billet throttle return spring bracket
    K&N air filter
    cold air box
    fuel filter and fittings
    polished stainless sidepipes and header tubes
    Tremec transmission mounts
    shift lever handle
    shift knob
    Kirkham aluminum Salisbury reproduction differential
    differential breather assembly
    drive shaft
    half shafts (2)
    drive shaft safety loop
    Penske shocks with Hyperco springs
    complete brake system
    billet reservoir cans
    Goodyear "Big Letter" racing tires and wheels
    side pipe cutout labor
    assembled
    fill and bleed brake system
    The Ultimate Hot Rodder's Garage Package Includes:
    NewAge 6pc Garage Cabinet System
    Kirkham Motorsports 427 KMS/SC component vehicle (engine and transmission not included)
    456 square feet of Black and White Motofloor® Garage Tiles, your choice of color, 40 female edges and 2 Completer Packs. This is enough flooring to cover a standard 2 car garage.
    One BigHorn 36 ECB Safe
    One FlowWall Ladder Hook & Bin Bracket Set/Hook Starter Set
    One Racor Extreme Rack/Ladder Lift/Heavy Duty Rack/Golf Storage Hanger/Garage PRO
    One Trinity 41" Stainless Steel Toolbox
    1 two ton capacity breakdown engine crane
    2 six ton capacity ratcheting jack stands
    1 three and a half ton capacity professional low lift height jack that can lift to a height of 21 3/8"
    This NewAge Products 6-piece heavy-duty professional series cabinetry set is an excellent solution for the small workshop or garage. This cabinetry system features either a stylish gray and black powder-coated finish or a taupe and charcoal grey powder-coated finish that is designed to handle the toughest of garage conditions. The superior strength and durability of the professional series cabinetry set provides an excellent solution for finishing your garage. Cabinets come fully welded, requiring little to no installation.
    Features:
    More Details
    Available in 2 color options
    Gray doors/drawers with black cabinets
    Taupe doors/drawers with gray cabinets
    Heavy-duty 18-gauge steel
    Heavy-duty powder-coat finish stain and scratch resistant
    Stylish chrome accents
    24" Deep counter top space
    Steel pegboard side panels inside cabinet doors for hanging storage of tools, electrical cords, etc.
    Powerful magnetic door latch to securely shut doors
    Inner steel walls for added strength and durability
    Total 6-pc set: 7.5 ft wide
    Warranty: 10 years against manufacturer’s defects
    Motofloor® Garage Tiles is a durable, multi-purpose floor system designed to give you a clean professional work environment that can withstand tough mechanical environments. It’s oil, grease, petroleum, antifreeze and chemical resistant. Great for garages, shops, retail displays or anywhere tough flooring is needed. Easy to set up and clean.
    Features:
    More Details
    Patented multi-purpose floor system designed to give you a clean professional garage
    Made from high impact copolymer
    Built to handle extreme rolling loads
    Engineered to withstand tough mechanical environments
    Resistant to oil, grease, petroleum, antifreeze and most household chemicals
    The Bighorn Classic 36ECB will give you unparalleled peace of mind and security against fire and theft. This safe features thick heavy bodied construction, outstanding 45 minute/1200 degree fire protection, fine styling and interior, and the industry's best warranty and customer service.
    Meets or exceeds the CADOJ acceptable gun safe standards
    Security Features:
    More Details
    UL Listed electronic lock
    5.75” thick door
    Spring loaded re-locker keeps safe secure if lock is tampered with or removed
    Massive 1.5” diameter locking door bolts
    3 layer armored hard plate to protect the lock
    12 total locking door bolts, 3 way active
    4 sided door bolt protection
    Heavy bodied construction – 790 LBS
    The Racor Ladder Lift is the perfect way to store any ladder overhead and free up extra garage space. The Ladder Lift uses a rope and pulley system along with a fixed hook that is mounted to your ceiling. You can easily lift a 150lb ladder up to 12 feet. Just place the top of the ladder onto the fixed hook, attach the strap to the bottom of the ladder, and pull the rope. When you’re ready to use the ladder, unlock the rope and lower it. The pulleys and the fixed hook do most of the work, making an 80lb ladder feel like it’s only 10lbs: an 8:1 mechanical advantage. A unique locking mechanism holds the rope securely in place to prevent accidental release.
    More Details
    Store and organize your sports equipment with a minimum amount of space with the Racor ProStor eXtreme Sports Rack. Its unique design with four levels of storage allows you to stuff or toss any bat, ball or shoe for easy clean up. Made of heavy-duty steel tubing and nylon nets for extra durability.
    More Details
    The Racor, multi-purpose wall storage rack offers a handy solution for storing long items. Each of this rack's 3 tiers can hold up to 150 lb. providing 450lbs of total weight capacity storage for skis, snowboards, wakeboards, ladders, lumber, patio umbrellas, and more.
    Easily stores a variety of items:
    More Details
    Lumber
    Ladder
    Skis
    Umbrellas
    Long-handled tools
    The Racor GaragePro nine-piece kit provides superior strength, the ultimate in flexibility, and a variety of storage options for use in limited space. Plus, it expands as your storage needs grow. It starts with two 24-inch rails that can be hung separately or combined to create 48 inches or four feet of storage. These rails hold up to a combined weight of 1000 pounds for your heaviest items.
    The GaragePro has adjustable hooks and a shelf that can be easily placed on the rails and later moved wherever you need them. The shelf also acts as a handy place to store tools such as screwdrivers, wrenches, and hammers. Order yours today, and reclaim your garage!
    More Details
    Between rounds of golf you want to put your golf bags and shoes in a place where they will be safe and out of harm’s way. The Racor Golf Storage Hanger creates a safe and secure location to store two golf bags and two pairs of shoes on the wall–getting them off the floor to free up extra garage space and keep them critter free. Constructed of steel with a durable epoxy finish, the Golf Storage Hanger is designed for stability, corrosion resistance, and for rust-free storage. Then, when you’re ready to hit the greens, the Golf Storage Hanger has all your golf equipment is in one place!
    More Details
    No assembly required; installs into one stud. Order yours today, and reclaim your garage!
    TRINITY's heavy-duty professional-grade stainless steel rolling tool chest is built to provide all your shop and garage needs. Its high-end design and functionality not only make this tool chest a great value, but its large size ensures room for all large and small tools. In addition to this, the four wheel design provides heavy-duty tool storage that is still versatile enough to allow for easy mobility.
    More Details
    41” wide tool chest
    2,200 lbs. weight capacity
    Split top chest for smaller parts and full length bottom drawers for large tools
    3 – split top 2.5” deep drawers
    2 – split top 5.5” deep drawers
    1 – split top 8.75” deep drawer
    1 – 2.5” deep drawer
    3 – 5.5” deep drawers
    1 – 8.75” deep drawer
    Custom delivery of your Kirkham Motorsports 427 KMS/SC component vehicle is included in the quoted price and delivered by Rich’s Classic Transport. For all your custom transport needs, contact Rich's Classic Transport at: richsclassictransport.com
    Sales Tax collected on this item does not qualify purchaser for any local, state or federal exemptions on applicable excise taxes or fees when licensing this Kirkham Motorspots 427 KMS/SC componet vehicle once completed. Please check with your local, state or federal agencies to verify if additional taxes and fees will be charged to license your completed Kirkham Motorsports 427 KMS/SC component vehicle.
    To purchase please contact Costco.com at 425-427-7145.
