Need help verifing correct engine on 1965 gt350
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by butchiepaul, Dec 21, 2012.
  1. butchiepaul
    butchiepaul New Member
    Fellow members. I am a newbe to the Shelby Forum, have fooled with mid-year Corvettes most of my life and don't know much about Shelbys. I have found a barn find, 1965 GT350 in need of restoration. What I need to know is how to tell if the engine is correct to the car. Any help would be greatly appreciated.
  2. Snakepit
    First the "engine" is a collection of a bunch of parts so you would have to go through each (opening up the motor) to check everything. Not unusual to find K code heads on a standard lower end or a K code block with a standard crank and rods.
    From the out side of the engine you can determine what the carb and dist is by looking at the part number and dates. You can look at the balancer to determine if its a thick K code style with the correct edges and not a C8 service replacement item.
    Heads - check for the number on the front or rear boss where the alternator or PS (yes I know they didn't have PS but for description purposes) would attache. The large cast number should be a 19-21. Removed the valve covers and check for reinforcements/ pockets for the valve springs cast into the head
    Block- check for the original cars VIN (in this case Ford VIN) above the oil pan surface passenger side near the front edge
    Hope this helps
    rshelby likes this.
  3. Coralsnake
    You should also consider contacting the 65 Registar. MNy of the 65 cars have good established histories. There just arent many around.
  4. Snakepit
    Agreed - your assuming that its a real Shelby at this point lots of fakes and rebodies that have been sitting in barns for many many years. Great place to start
    With that said if you having difficulty identifying the engine then your likely not going to have an easy time with the car/rest of the car. I suggest you find an honest experienced person to look at the car before dollars get exchanged (unless their giving it away) Everyone I know hates breaking the news after someone has purchased a car - would rather be the one saving you from becoming "that guy"
    There are a small handful of people both educated enough to help you determine what the car is and you won't have to worry about them trying to buy the car from under you (a common concern at this point I'm sure) But they are out there, will cost a few dollars to get them they and to look at things but it will be well worth in
    Good luck and let us know how it works out for you - love those success stories and even if it does not write back since many can learn from even things that don't work out ;)
    IF either of us can help I'm sure each would welcome a PM to help further if you choose to
  5. BillH
    BillH Well-Known Member
    In addition to the above, keep in mind that some of the most expensive, hardest to find parts for these cars have little to do with the HP engine. (original horn button, horn switch and the correct date correct carburetor to name a few)
  6. gjz30075
    gjz30075 Well-Known Member
    Roswell, Ga
    To the OP: did you actually purchase the car? Any pics would be appreciated.
    Greg Z
  7. mrmustang
    Jeff and Coralsnake both offer the best sound advice. Contact the SAAC registrar before you spend your money to confirm you are not buying a clone or a rebody.
    Bill S.
