lookin to buy a GT350
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by manana, Dec 1, 2010.
  1. manana
    manana New Member
    my first post,
    i am looking for a 1966 GT350, does anyone know anything about SFM6S 1545
    it is red with white stripes? i would appreciate any help as i am new to the shelby mustang world and need all the help i can get.
    thanks.
    rocky 1634
  2. 67GT500#2100
    I don't know anything about this car but it sure looks nice in the pictures I have seen. I would see if you can get a Shelby expert to look at it in person. What part of the country is the car currently located in?
    Here is one of the pictures I found.
  3. ross0133
    ross0133 Active Member
    IT does look like a nice unit but it does lack a few things like the correct distributor, T oil pan and it says in the description that it has no rear brake ducts...hmmmm. Seat belts are the wrong type and they may be more if you dig deep enough.
    It seems to have a fair degree of metal replaced.
    Best thing to do is to have the car inspected by an expert in the field.
    Good Luck
  4. 67GT500#2100
    Here is a link to a seemingly very honest description of the car. Still do your due diligence and get the car checked out.
    http://www.collectorcarsforsale.com/110616238158-ford-mustang-shelby-gt350-1966-ford-shelby-gt350-mustang-fastback-/detailse.html
    Here is part of the description.
    "She has been in an accident or two; maybe from racing or not, she shows that body parts and front core support and inner fenders have been replaced, you can tell this was done (30?) years ago since the metal was used from another mustang and the body work looks a "much older" time frame. So the inner fender and core body work was untouched as we wanted to leave its history intact, not hiding the work or replacing it with aftermarket metal. Some people would just consider this as part of repair or restoration, or a partial re-body since the parts were core to the car. Also, the rear passenger quarter panel was also replaced, not knowing from what; but I would say it was at a different time then the front work; becouse new re-production metal was used.
    SCCA shows that this car had had many owners up to the mid 80s and I had found out in research that at one point she was a theft recovery car that was away from the public for 20+ years. "
  5. stephen_becker
  6. 1966GT350-5
    1966GT350-5 Active Member
    Colorado USA
    The most glaring thing that I see wrong with the car is the export brace has the paired bolt holes not equally spaced.
  7. chris NOS
    chris NOS Member
    there's a lot off things showing " red light" on this one... better get it inspected before involving any kind off money !!!
  8. Coralsnake
    I agree. Find someone that's knowledgeable and doesn't have have another agenda (like selling you a car) to help you.
    If the inner aprons have been replaced, there is very good chance the Ford serial numbers are gone. If the numbers are gone, the value of the car is significantly decreased.
    :ph34r:
  9. zrayr
    zrayr Well-Known Member
    TX
  10. Texas GT350
    Texas GT350 Well-Known Member
    Houston, Texas
    Are the hood pins in the correct location?
  11. 1966GT350-5
    Colorado USA
    Quick answer, without giving out too much info, NO.
  12. shelby6t5
    shelby6t5 Well-Known Member
    I could not have said that better, or more timely! ;)
    M.
  13. ross0133
    I couldn't agree more. A quick check of any pics of all other genuine Shelby GT350's will show that they are in the wrong place. I pretty sure I mentioned that the more you dealve into this one the more the mystery deepens.
  14. zrayr
    TX
  15. nastyford
    nastyford New Member
    The 4X4 look.............priceless
