I've been told that the dual exhaust cutouts on '67 Shelby's used a '65-66 dual exhaust trim ring that had the bottom part cut off to fit the '67 valence panel.Is this true? Also,was this trim ring discontinued being used at some point? My '67 has the original paint.The rear valence has the 3 small holes around the cutout where it looks like a trim ring had been mounted but I was told by someone my car is too "late" to have the trim rings.My car is #910.Does anyone know if it was possible for my car to have the trim rings? Thanks in advance for your help.
I really don't know the cutoff date, but it was fairly early in production. You said you have 3 holes. Is the cutout fm the factory dual exhaust setup or is your valance been "hand cut". Mine is an early car and when the trim is removed, you can see that the cut out is very rough.
The cutouts on my rear valence are very rough also.Looks like it was done by hand.Definitely not stamped.
#910 really isn't that early, but from what you described, it certainly looks like yours had the 65-66 modified GT trim rings.
The exhaust trim is indeed a 65-66 oval bezel, cut in half... I own car #130...with the trim bezels...when I restored the car in 1982, it surprised me that they had used these bezels... Not much written info in the early 80's on early '67 cars...
Built in March of 1967, it would seem unlikely your car was built with them. But the holes are there, so, maybe it was a special project set aside that didn't pan out. Or, some new cars just have problems, maybe yours got built, then set in storage, the battery went dead, and nobody wanted to deal with changing it. The evidence, as already mentioned: the curves are hand cut. If yours don't look that way, maybe the next owner(s) decided to put them on. Doesn't matter, the holes are cut so put them on. By the way, there is very little about this car in the registry, so mail in what you have, so it will get into the next registry...which is coming soon.
Roddster's explanation is plausible. Not sure if it's possible, but you could ask SAAC if your Ford vin is within the range of very early cars.
Let me explain further for 2 reasons: 1) I used to work at the Chicago Chrysler pre-delivery center starting in 1970. Some cars just did not run well, or, the battery went dead so it sat a week or two.....or three. 2) I've studied the registry and, some, but not a lot, nor very many ,67 Shelbys somehow got finished or shipped somewhat out of order. A Marti report might give some more concrete dats as to build dates and shipping. Get one at www.martiauto.com
Thanks for the help guys.Since it has the 3 mounting holes around the rough cutouts,I think I will put the trim rings on.I guess a previous owner could have put the holes in but the valence is the original one with original paint and still has the paper sticker that goes behind the licsence plate stating to remove the tie downs before releasing car to customer. I have forwarded all the info I know to the '67 registrar for the next registry.Both the hood and trunk lid on my car completely fiberglass and not the steel/fiberglass.I am sure I will have alot of other questions as I am new to the Shelby's.Thanks again...Greg.
Here is another thing to scratch your head about......... I have noticed that the 67 Shelby's with the Chrome Trim and In-Board High Beams also had a differant High Beam set up. I have photos that show the High Beams were mounted where about a half inch stuck out of the Grille and had a thick Black Trim Ring where as the later 67 Shelby's had the High Beams mounted Flush with the Grille and had a flat Trim Ring that I think was Chrome.
Yep, that is typical of the first few cars. It's called a one-piece grille with black trim rings for the center lights and body-colored outer trim rings for low beams.
If you think in terms of - the enter 1967 production as a running production change, it's way easier. About every 300-400 cars something changed. You have to own one to care, and them also go look at other 67' Shelbys.
In the process of restoring my car,I took the rear tailights out of the Shelby.Once I took the fiberglass tailight panel out,I could see the number "142" written in white markel on the metal piece that was left and right above the rear valence on the right hand side.I also had a closer look at the rear valence exhaust cut outs and you can definitely see a ring outline on the paint.Does anyone know what the 142 might stand for? Thanks...Greg.
Usually workers are considered Numbers. So the 142 could be the assigned number of the person who was working on or inspecting your Shelby.
