67 GT-500 Questions
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by Lugnut, Jan 27, 2006.
  1. Lugnut
    Lugnut Well-Known Member
    Corpus Christi, Texas
    Ok, we're getting close to actually starting #1212 for the first time in oh, say...20 years! Anyway, a couple of questions:
    1. The center headlights, do they come on when you hit the high beam switch or is there a separate switch?
    2. The carbs...do they work as a pair or does one open before the other?
    Thanks!
  2. dwdshelby
    dwdshelby Active Member
    On mine - I have inboard lights and they come on when you hit the high beam switch on the floor. The dual quad carbs (BJ and BK) use a progressive linkage so the front carb opens first for just off idle and then the linkage progressively opens both so that both carbs reach WOT together.
  3. The Commissioner
    Georgia
    Your high beams come on when depressing the foot switch so all 4 lights should be on. I've got a wussy GT350, so I've only got one carb, but would assume it should operate one, and when you "shower down", the other becomes operational thru the linkage set up, but that's a guess.
  4. d_ford
    d_ford Well-Known Member
    Nelsonville, Ohio
    Yup....
    What dwdshelby said.
    Doug
  5. 67GT500#2100
    If you need pictures of the linkage let me know and I'll post some pictures.
  6. Texas Swede
    A common problem with the 67 Shelby headlights is the
    bi-metal circuit breaker in the switch. Mustangs were
    made with only one pair of lights and consequently have a switch
    that matches. Shelby 67's use two pairs of headlights
    which draw too much current for the standard switch.
    I was driving my 67 in Sweden late at night and it was completely
    dark outside and the lights went off and then came back on after
    a couple of seconds. Changed from high beam to low and was able
    to drive that way home. Solved the problem by changing the switch to
    a full size Ford unit with two pairs of headlights. Had to move the old
    bracket on to the new switch but the problem disappeared.
    Just a tip if it happens to you.
    Texas Swede
  7. dj_b0by
    dj_b0by Member
    romania/craiova
    :confused: how much hp has a fully mod gt500???:confused:
