67 GT-350 C-4 servo "A" or "C"
Discussion in '1965-1970 Shelby Mustang GT350 & GT500' started by rugcookie, Apr 24, 2008.
  1. rugcookie
    rugcookie New Member
    Virginia
    I posted this on the HiPo forum and received several answers. I hope that someone who has/had an original 67 GT-350 with an automatic transmission can answer this.
    According to the 1997 Shelby World Registry page 1299, the C-4 trans has the "A" intermediate servo piston and cover. In the HiPo Registry 4th edition page 64, the 1967 C-4 specs do not include the "C" servo. What is the correct C-4 trans for a 67 K-code auto- equipped car?
    I have one of the last 12 67 GT-350's built. It has a July Ford build date. It has the "A" servo and cover, but I am not the original owner and the transmission may not be original. The tag is missing-prior owner lost it during rebuild? Does anyone out there have a late 67 K-code automatic car that can verify which servo is correct?
    Thank you
  2. markboss
    markboss Well-Known Member
    The '67 GT350's did use an "A" code servo....
    You can upgrade to an "H" or a "C" for about $100..and it really makes a difference...
    Mark
  3. cobrajeff
    cobrajeff Member
    Motor City USA
    Mark - I'll take ALL of the usable "C" servos (original OR repro) that you can come up with for $100.
    Cookie - There will definately be a noticeable difference between the "A" servo and an "H" or a "C". As I said on another forum, the "A" servo is correct for a '67 GT350 C4, but a "C" servo will make an improvement in the 1-2 shift that you'l be able to feel with no other modifications.
    Did you pull the pan and check the tag on the valve body yet?...or the tailshaft and check the governor?
    regards,
    cobrajeff
  4. markboss
    Check ebay...Billett c code servos there...also "H".
    ebay.. 380016706696
    billet "C" servo $89....
    how many do you want..I will make 5 bucks off this deal!!
  5. markboss
  6. rugcookie
    Virginia
    Thanks for the information on the servo. I will take a closer look at the transmission later this summer.
    Rugcookie
  7. lashss
    lashss Well-Known Member
    Washington, DC
    Mine, #2011 has an "A".
    LS
